Find pair of value on nested list
  • September 20, 2019
  • 27 views
alc33
Forum|alt.badge.img+14
Hi!
I would like to compare 2 datasets. I have 2 lists :
dataset1 = the reference
object 1 : this object have 2 attributes and 2 layers associated :
_listattrib{0}.ATTRIBUT (string) = ATT1
_listattrib{0}.LAY (string) = LAY1
_listattrib{1}.ATTRIBUT (string) = ATT2
_listattrib{1}.LAY (string) = LAY2
dataset2 = the data to check
object 1 :
fme_attrib_info{8}.field_name (encoded: UTF-16LE) = ATT1
fme_attrib_info{8}.layer (encoded: UTF-16LE) = LAY3
I would like to find if the object1 from the dataset 2, has the same attribute and layer values than in the dataset1.
Here, I would like to show that the association ATT1/LAY3 is wrong. The correct association is ATT1/LAY1.
I find a solution with concatation, featuremerger and listsearcher but I would like to have a more correct solution, like use a Listsearcher but with a pair of values.
I find something with PythonCaller but I don't use to write on Python.
https://knowledge.safe.com/questions/3825/search-nested-list-elements.html
Thanks!
Forum|alt.badge.img+46
I'm not sure there is a more correct way without using python
