Hi, I have two readers where one is a line object and the other is a point object. Sometimes, my point objects will lie on the line or it may be at the end of a line. In the case that it is on the line, I want to split the line and be able to produce two lines. Please advise. Thank you very much!
Split chain at point intersect
