open excel workbook on shutdown tcl / python
  • March 4, 2015
  • 37 views
bubblebeb
I have a routine that writes data into rows in Excel through a workspace runner but once the routine is finished I want FME to open the spreadsheet.
I have looked at both python and TCL but can't get anything to work without runtime errors.
Does anyone have any scripts I would use to simply open an xlsx in a shutdown script.
gio
Forum|alt.badge.img+15
  • March 4, 2015
Hi, you can use in start up:
   set filename {yourfilenameinclpath}
   set shortname [file attributes $filename -shortname]
   exec cmd.exe /k start $shortname &
  • March 4, 2015
In a Python shutdown script in Windows the following works:
import os
os.system("Book1.xlsx") # Assuming your filename is Book1.xlsx
If this doesn't work, you can include the "start" word:
import os
os.system("start Book1.xlsx")
If your XLSX is in another directory than your FME script, give it an absolute path.
gio
  • March 5, 2015
shutdown i ment, and it is a tcl snippet
bubblebeb
  • March 6, 2015
Many thanks for both Gio and JimO's responses. It is now working using the Python script
import os
