Getting the error: Python Exception : No module named parser
  • May 24, 2017
  • 11 replies
  • 508 views
When I´m trying to read a layer using the ArcGIS Feature reader it´s resulting in the following error:
Creating reader for format: Esri ArcGIS Server Feature Service
Trying to find a PYTHON plugin for reader named `ARCGISFEATURES'
Loaded Python module `arcgisonlinefeatures' from file `C:\\apps\\FMEBeta\\plugins/python27\\arcgisonlinefeatures\\__init__.pyc'
Python Exception <ImportError>: No module named parser
Could not create Python Reader `ARCGISFEATURES'
The weird thing is that in the scripting parameter the Python compatibility is set to Python 3.4+ but still it´s using the Python 2.7 plugin?
I´m using the latest build (20170517 Build 17494).
Christian
carsonlam
Forum|alt.badge.img+7
  • May 29, 2017
Hi @rkcha - that does seem incorrect. Can you open a support case with us to help us investigate the issue?
  • May 30, 2017
Thanks for looking into it, Carson. If you could keep us updated on the results here as well it would be much appreciated.
warren156
  • August 10, 2017
Hi @carsonlam can you provide any update on this issue? I appear to be getting the same error.
Thanks,
Warren
warren156
  • August 10, 2017
Thanks,
Warren
By the way, I'm using build 92017.1.0.0 (20170731 - Build 17539 - WIN32)
Warren
trentatsafe
  • August 10, 2017
Hello @warren156
I believe the issue is when there are leftover modules from a previous FME installation.
Try deleting the following files:
fme\\python\\js2py\\translators\\pyjsparser.pyc
fme\\python\\js2py\\translators\\pyjsparserdata.pyc
fme\\python\\js2py\\translators\\std_nodes.pyc
These are the old .pyc files from the older FME installs.
This should resolve the issue. Please let me know.
warren156
  • August 10, 2017
Hello @warren156
Hi @trentatsafe that worked perfectly! thanks!
Warren
samisnunu
Forum|alt.badge.img+12
  • August 11, 2017
I had the same error message when upgraded to the newest build 17539.
I followed @trentatsafe comment, and it worked!
For the next FME update, I hope it'll automatically delete the older .pyc files.
helmoet
Forum|alt.badge.img+8
  • September 15, 2017
Removing the old pyc files as instructed works fine. BIG hug @trentatsafe!
aaron
  • December 5, 2017
I got the error with build 17536 and again with 17652. Happened when trying to access both Mapbox and ArcGIS Online background maps. Agree that it would be best to remove these files with a future installer. This post, and therefore the solution, was not easy to find.
debbiatsafe
Forum|alt.badge.img+21
  • February 17, 2018
Hi @sami_snunu, @aaron, and others
The installer will now clean up any leftover files within Python directories upon uninstall in FME 2018.0 and newer. This should make in-place upgrades a little smoother.
Thank you for your patience as we worked to resolve this issue.
Kind regards,
Debbi
Hello @warren156
@trentatsafe can you please let me know the full path, can't seem to find it and I am having the same issue. thanks in advance!
