Failed to write Sketchup file
  • June 24, 2018
  • 7 replies
  • 44 views
I cannot write a Sketchup file.
I have FME(R) 2018.0.1.1 (20180615 - Build 18312 - WIN64)
And the log says:
Reprojector: Using transformation `SWEREF99_to_WGS84,Forward(Geocentric,EPSG:1879)' when reprojecting from SWEREF-99-13-30 to SKP_COORDSYS_0
Failed to write Sketchup file to 'C:\\Temp//LAS.skp'
... Last line repeated 2 times ...
Translation FAILED with 2 error(s) and 0 warning(s) (2505 feature(s) output)
FME Session Duration: 3.8 seconds. (CPU: 3.2s user, 0.5s system)
END - ProcessID: 236, peak process memory usage: 117140 kB, current process memory usage: 93852 kB
Program Terminating
Translation FAILED.
What to do?
Best regards,
Jonas
Forum|alt.badge.img+62
First thing to try is adding a GeometryValidator before writing. Any invalid geometries will cause the writer to fail. See the documentation for some helpful tips.
  • June 25, 2018
Hi redgeographics,
Thanxs for that but it did not help.
I attache log file and LAS and fmw files in dem.zip
Best regards,
Jonas
Hi redgeographics,
Best regards,
Jonas
I do get a coordinate system error but it does write a Sketchup file. If it is coordinate system related you could try reprojecting to *XY-MT* right at the start of the process.
  • June 26, 2018
Nope, I cannot get it to work...
Best regards,
Jonas
Best regards,
Jonas
We're on different builds (I'm on 18310, you're on 18312), maybe that's it. Also, the one error I get is referring to a Csmap exception.
Are you using a custom coordinate system by any chance?
daveatsafe
Forum|alt.badge.img+20
  • June 27, 2018
Hi @bigjonas69,
I tried to reproduce the problem, but the file wrote with no errors for me. I wonder if there may be permission issues with the location you are writing to, or if you are trying to overwrite an existing file open in another application.
Please try writing to another location and see if that solves the problem.
  • June 29, 2018
Hi @bigjonas69,
Hi DaveAtSafe,
I have tried a different location now and it did not help...
And I have tried a FMW workspace from my job what is working fine there. But that same FMW worbench (I have to change the file locantions from input and output files) is not working on my home computer...
So there are something wrong with my home license or my FME installation at home...
Is there a limitation at home license?
Edition: FME Home Edition (node locked-crc)
Version: FME(R) 2018.0.1.1 (20180615 - Build 18312 - WIN64)
Locale: sv_SE
Codepage: 1252 (ANSI - Latin I)
Registration Key: 0-572-859-301
Registration: Evaluation License 352 days left
Best regards,
Jonas
