Splitting attributes
  • March 20, 2014
  • 5 replies
  • 156 views
nic_ran
Forum|alt.badge.img+16
I have an attribute value of the form: 1,2,3,4,...
I would like to split the attribute into separate values, using the comma as the delimiter.
I know I can do this with the AttributeSplitter but how do I get at the resultant parts? All of the examples that I've seen tell me to expose the attributes (right-click -> expose elements) which is fine if you know how many elements there are in the list but not if you dont know. I could have hundreds of elements...
The ListExploder doesn't work because the list doesn't have any attributes in it, just values.
I could write a Python script to do what I need but there must be an easier way?
Best answer by erik_jan
I tried and was able to do this without Python:
Used the AttributeSplitter to create a list.
Explode the list into features using the ListExploder.
Then rename the listattribute using the AttributeRenamer with new name attr_@Value(_element_index).
This will result in attributes named attr_0, attr_1 etc.
The merge the features using the Aggregator grouping on every attribute except the former list attributes.
Then you will have the split attributes as attr_0, attr_1 etc on the feature.
nic_ran
  • March 20, 2014
Hi David,
I was doing exactly that and it wasn't working.
I deleted my transformers and replaced them and now it's working. Guess I must have had some odd setting in them originally...
Thanks for your reponse.
Nic
  • December 1, 2015
i have the same question, but i can't see the answer from David
  • December 1, 2015
The ListExploder can be applied in many similar cases. Doesn't it satisfy your requirement?
erik_jan
Forum|alt.badge.img+26
  • December 1, 2015
  • December 1, 2015
If you want to do python it really is easy. Here is an example of one I did to split on a dash. Super simple:
you can prob make this work for how you want it or how you want to split it.
import fme
import fmeobjects
def processFeature(feature):
f_type = feature.getAttribute('F_TYP')
if f_type:
f_type_parts = f_type.split('-')
Height= f_type_parts[0]
Class= f_type_parts[-1]
feature.setAttribute("Height",Height)
feature.setAttribute("Class",Class)
