WMS Service creation- How to implement the GetFeatureInfo operation
Dear all,
You have an article explaining how to create a WMS Service. Two operations are explained: GetCapabilities and GetMap (https://knowledge.safe.com/articles/19640/how-to-create-a-wms-service-using-fme-server.html).
However, we also need the GetfeatureInfo operation. Is it possible with FME? I have not found information about this operation. It would be very helpful to have a .fmw for the GetfeatureInfo operation, in case it's possible to create it.
Thanks in advance and best regards,
Montse Marco
sigtill
Forum|alt.badge.img+24
  • September 4, 2019
Unless the image is very small and the workspace always takes less than 20seconds to complete, I would suggest using a dedicated WMS Server software:
https://en.wikipedia.org/wiki/Web_Map_Service
itay
Forum|alt.badge.img+17
  • September 14, 2023
I am also wondering if this is possible. I think the most challenging will be defining the coordinates from the client . The rest should be comparable to the GetMap request.
Did anybody successfully implemented this? @mmarco​ @deanatsafe​ ?
