AUTOCAD text to arcgis's annotation
Hello,
I am current migrating autocad text to arcgis annotation.
Apparently autocad store the text using line and point.
point - migrated using labelpoint
may I know how I can migrate text that are stored with lines?
the source is in oracle spartial database and output to enterprise geodatabase.
fmelizard
Forum|alt.badge.img+18
  • May 14, 2013
You could transform the lines into points....
  • May 14, 2013
using which function? I am thinking of using LabelPointReplacer
but for autocad
for different justification the text appear at different position of the line.
is there a theory behind this ?
fmelizard
  • May 14, 2013
If you are not too interested in the exact location you can use the center point replacer.
  • May 14, 2013
what is the exact name of the transformer?
fmelizard
  • May 14, 2013
You can also expose the XY justification coordinates and use that to create a point.....
  • May 14, 2013
Don't think it will work. becaue the point can be start, middle or end
left(point), middle and right justify.
fmelizard
  • May 14, 2013
Hi seesee,
btw why not try the labelpointreplacer on the lines?
and is justification a property used in ESRI products?
Hope this helps.
