Is there any fundamental change in the TopologyBuilder v8 (2016), or is is just a cosmetic renaming of the ports from Line and Area to Edge and Face?
TopologyBuilder 2016
Best answer by davideagle
This kind of detail is generally made available in the "what's new" text files that Safe publish on the download pages, like this one for the beta:
http://downloads.safe.com/fme/beta/whatsnew.txt
In here you'll find that the TopologyBuilder has been the subject of quite a lot of effort with 13 updates and fixes by my count. Here are the first 5 and the builds that they feature in:
========================== BUILD 16127 20151110 ========================== TopologyBuilder: Fixed bug ordering closed arcs around nodes (PR#65451)
========================== BUILD 16112 20151019 ==========================
Transformers: Use terms edge/face rather than line/area for topologybuilder output (PR64057) TopologyBuilder: Fixed bug rebuilding a donut from a self-intersecting polygon (PR#46199)
========================== BUILD 16102 20151002 ========================== Transformers: Update terminology in topologybuilder and make a single input port (PR64057) (PR63268)
========================== BUILD 16098 20150928 ========================== TopologyBuilder: Added option to automatically deaggregate input and rejected port (PR#47509). C80277, C80277
========================== BUILD 16095 20150923 ========================== TopologyBuilder: Fixed crash for rich input and a maximum number of coordinates (PR#64138). C22633
