Package Development: How Do They Work? (on a Mac).
  • August 10, 2025
  • 16 replies
  • 227 views
larue
Forum|alt.badge.img+12
I have been trying to set up a Package dev environment on a Mac (Sonoma 14.7.7) and it crashes every time I get to the ‘import fmeobjects’ test in the venv.  Just getting that far was a huge hassle.  It appears that the SDK instructions and fme-packager library are geared for Windows.
I had to modify the fme_env.pth file to only show the FME Home path and get rid of the rest, for instance.  The issue seems to be that the native FME python 3.13.5 library does not like the Python.org 3.13.5 library, but can’t say for sure. Are Macs even supported for this?  I currently don’t have access to v2025 on Windows.
If anyone has had success making packages using MacOS, any insight is appreciated.  Bonus points if you have a good ICP reference!
Thanks,
-Loren
Best answer by carsonlam
We regularly develop packages on MacOS, so that’s unexpected. We also use the interpreter from python.org in a virtualenv, configured using fme-packager config-env. Is the value of sys.version different between FME Python and your own installed Python?
carsonlam
Forum|alt.badge.img+7
  • August 12, 2025
larue
  • August 12, 2025
Hi ​@carsonlam,
I made a point to match versions and thought they were both 3.13.5, but in reality FME is running 3.13.2 !
Is it published somewhere when they update the version, or do you just doublecheck with PythonCaller?
That was easy, many thanks!
-L
carsonlam
  • August 12, 2025
The quickest way to check the specific Python version is through PythonCaller or ./fme python to open a REPL.
Even though your FME has Python 3.13.2, its binaries for fmeobjects should still be compatible with Python 3.13.5, so it’s strange that the mismatch appears to make it not work.
FME 2025.1.1 b25615, released last week, should include Python 3.13.5 for MacOS.
larue
  • August 12, 2025
I usually work on a PC, so it’s hard to know sometimes if it’s me or MacOS.
To be clear, you do NOT need to alter the fme_env.pth file?  Here is what I get:
#/Library/FME/2025.1/python
/Library/FME/2025.1/python/python
/Library/FME/2025.1/python/python/fme-plugins-py313.zip
/Library/FME/2025.1/python/python/python313
/Library/FME/2025.1/python/fmeobjects/python313
import fme_env
To get any further with the setup, I had to delete everything except for the top line, which I uncommented.
 Let me try the new build and we’ll see what happens.
carsonlam
  • August 12, 2025
Based on your fme_env.pth, it looks like fme-packager config-env is working with a FME_HOME value of /Library/FME/2025.1/python. It should instead be /Library/FME/2025.1. Your environment should be set up after config-env without needing any manual edits to fme_env.pth.
larue
  • August 13, 2025
Well, I installed 2025.1.1 and the versions now match at 3.13.5.    Still can’t get past the ‘import fmeobjects’ test.  Module was not found.
When I ran  fme-packager config-env,  it would not accept  /Library/FME/2025.1, nor /Library/FME/2025.1/python.  They did ‘not exist’.
It would only finish if I used  /Library/FME/2025.1/Apps/FME Workbench 2025.1.app/Contents  or /Applications/FME 2025.1/FME Workbench 2025.1.app/Contents
I had to give r&w access to these folders, and still no dice.   Any ideas?  This is ridiculous.
carsonlam
  • August 13, 2025
You’ve found a bug where fme-packager config-env requires FME_HOME to be a writeable folder. That’s not needed. I’ll get that fixed.
In the meantime, for your specific case of getting fmeobjects on Mac, just replace the contents of fme_env.pth with /Library/FME/2025.1/python. That should fix the ModuleNotFoundError that you’re getting from import fmeobjects.
If you’re getting a different kind of ImportError, or a process crash, then please share the output and we’ll investigate further.
larue
  • August 13, 2025
I think I got a clean venv now, but it still crashes at import fmeobjects:
Time Awake Since Boot: 360 seconds
System Integrity Protection: enabled
Crashed Thread:        0  Dispatch queue: com.apple.main-thread
Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
Exception Codes:       KERN_INVALID_ADDRESS at 0x0000000000000010
Exception Codes:       0x0000000000000001, 0x0000000000000010
Termination Reason:    Namespace SIGNAL, Code 11 Segmentation fault: 11
Terminating Process:   exc handler [1014]
VM Region Info: 0x10 is not in any region.  Bytes before following region: 4297900016
      REGION TYPE                    START - END         [ VSIZE] PRT/MAX SHRMOD  REGION DETAIL
      UNUSED SPACE AT START
      __TEXT                      1002cc000-1002d0000    [   16K] r-x/r-x SM=COW  /Library/Frameworks/Python.framework/Versions/3.13/Resources/Python.app/Contents/MacOS/Python
Thread 0 Crashed::  Dispatch queue: com.apple.main-thread
0   libpython3.13.dylib                      0x102161978 PyDict_New + 32
1   libpython3.13.dylib                      0x10219a7cc type_ready + 504
2   fmeobjects.cpython-313-darwin.so           0x100d31d8c PyInit_fmeobjects + 48
3   Python                                   0x101684754 _PyImport_RunModInitFunc + 84
4   Python                                   0x101681294 import_run_extension + 92
5   Python                                   0x10168331c _imp_create_dynamic + 936
6   Python                                   0x1014f1650 cfunction_vectorcall_FASTCALL + 96
7   Python                                   0x101618acc _PyEval_EvalFrameDefault + 54736
8   Python                                   0x10146ff9c _PyObject_VectorcallTstate.824 + 72
9   Python                                   0x101472324 object_vacall + 244
10  Python                                   0x1014721bc PyObject_CallMethodObjArgs + 108
11  Python                                   0x1016803a8 PyImport_ImportModuleLevelObject + 3316
12  Python                                   0x1016271ac _PyEval_EvalFrameDefault + 113840
13  Python                                   0x1016095f8 PyEval_EvalCode + 132
14  Python                                   0x101603704 builtin_exec + 396
15  Python                                   0x1014f1778 cfunction_vectorcall_FASTCALL_KEYWORDS + 88
16  Python                                   0x1016154b8 _PyEval_EvalFrameDefault + 40892
17  Python                                   0x1016095f8 PyEval_EvalCode + 132
18  Python                                   0x101603704 builtin_exec + 396
19  Python                                   0x1014f1778 cfunction_vectorcall_FASTCALL_KEYWORDS + 88
20  Python                                   0x1016154b8 _PyEval_EvalFrameDefault + 40892
21  Python                                   0x1016dfc88 pymain_run_module + 196
22  Python                                   0x1016df6d8 Py_RunMain + 1504
23  Python                                   0x1016e0cb8 pymain_main + 436
24  Python                                   0x1016e0e14 Py_BytesMain + 40
25  dyld                                     0x1986d3154 start + 2476
carsonlam
  • August 13, 2025
Thanks for the report. I’ve filed a ticket with those details for the responsible team to investigate.
larue
  • August 15, 2025
Much appreciated.  They are welcome to reach out if they need more info or a real-time demo.
-L
carsonlam
  • August 15, 2025
As a workaround to this problem, instead of using a Python from python.org, make a virtualenv from the Python interpreter included with Mac FME: /Library/FME/2025.1/fmepython313/bin/python3 -m venv .venv
Then proceed as before: run fme-packager config-env and replace the contents of fme_env.pth with /Library/FME/2025.1/python.
larue
  • August 15, 2025
I managed to get through   import fmeobjects,   all the way to setting up the package with
 fme-packager init transformer.  Couldn’t get past installing dependencies though:
fme_demogreeter % pip install -e .[dev]
zsh: no matches found: .[dev]
carsonlam
  • August 15, 2025
For zsh, use pip install -e '.[dev]'
larue
  • August 16, 2025
Hi ​@carsonlam,
Thanks again for your help.  I managed to get a package made yesterday with only .fmx files (no Python ready yet).   It would be nice to have the same interface as the Python ones, but it worked as designed.
One thing you might want to look into:
When using
fme-packager pack
I was getting errors regarding the Category.  What I found was that the categories which are in quotes, like “Format Specific”, cause the error.  Once I set Category to only Geometry, it was all good.
Here is a snippet of a header showing the issue:
#! <TRANSFORMER
# TRANSFORMER_BEGIN CAD_WALL_PREPold,1,"""Format Specific"",Geometries",02b44c6d-15d0-4ab3-812f-0bd183c3f062,"Embedded Always",No,NO_PARALLELISM,$(FME_PROCESS_GROUP_BY),No,25615,YES,No,313,No,,both
The error pointed to this function:
def parse_custom_transformer_header(line):
Parses custom transformer header.
:param str line: Custom transformer header line from FMX.
:return: Parsed header
fields = line.replace("# TRANSFORMER_BEGIN", "").strip().split(",")
header = NamedTransformerHeader(*fields[: len(NamedTransformerHeader._fields)])
return header._replace(version=int(header.version), build_num=int(header.build_num))
I have a feeling the extra quotes were the issue.  What do you think?
Best,
@larue
carsonlam
  • August 19, 2025
There’s a problem with the handling of multi-category custom transformers. I have a fix ready, and it’ll be included in the next release of fme-packager.
carsonlam
  • September 22, 2025
fme-packager 1.17.0 should fix the problems you’ve identified. I’ve also updated the pip commands in the SDK Guide to support zsh. The upcoming FME 2025.2 release will restore the ability to use a python.org Python interpreter with fmeobjects on macOS.
