How to check if value in one table exists in another table?
  • March 26, 2018
  • 7 replies
  • 706 views
Hi there,
I have a table (lets call it TableA) which contains a field (lets call it Types). I need to compare each value in the Types field with ALL of the values in another field (lets call it OriginalTypes) which is in another table (lets call it TableB). If there is a match a value gets updated, if not nothing happens.
Currently I have these 2 tables feeding AttributeManager which has a Condition Statement checking if Types In OriginalTypes but this is not producing my expected results.
Any thoughts on what I am doing wrong here or what might be a better approach?
Regards
Best answer by erik_jan
I would use the FeatureMerger transformer (joining on Types = OriginalTypes):
Merged output: exist in both
Not Merged output: exists only in A
UnusedSupplier output: exists only in B
erik_jan
Forum|alt.badge.img+26
  • March 26, 2018
  • March 26, 2018
I do not want to merge anything, just check to see if the value exists in another table.
erik_jan
  • March 26, 2018
But trying to merge the features shows if they exist in one or both datasets.
To speed up the process you could even remove all other attributes and duplicate values before the FeatureMerger, using AttributeKeeper and DuplicateRemover transformers.
The you end up with a list of types from both (Merged), from only A (Not Merged) and from only B (UnusedSupplier).
  • March 26, 2018
Ok, that makes sense. So how would I go about using that list in the Condition Statement? When I try to use the list it makes me choose a specific value instead of the whole list.
erik_jan
  • March 26, 2018
I added a screenshot of the workspace:
  • March 28, 2018
Hi @potterman81,
FeatureMerger is the tool you want to use as @erik_jan suggested, see the attached workbench. featuremerger.fmw
FeatureMerger will merge the attributes from TableB to TableA however if the matching attributes are the same and TableB has not other attributes then it will work the same as a conditional statement as no new attributes would be added (See Example 2)
  • March 28, 2018
Hi @potterman81,
Thanks for the additional explanation, I am still new at FME and am still trying to wrap my head around the workflows but this is starting to make sense. I will mark this as the accepted answer but both yours and @erik_jan are correct. Thanks guys for your assistance with this!
