How can I convert an attribute of type string (but all digits) to type integer?
  • April 7, 2018
  • 6 replies
  • 1048 views
I keep getting an error in my translation because one of the reader attributes is a string (utf-16) and I'm trying to read it into an integer attribute in the writer. But I can't seem to find a way to convert it. I'm sure I've accomplished this in the past but can't remember how and am not seeing anything in the docs about how to do this specifically.
  • April 7, 2018
Hi @ieukcoca, generally FME implicitly converts data type of an attribute value if necessary, according to the destination schema you have configured. A string representing digits should be written into an integer type attribute in a destination feature type without any explicit type conversion.
If it's a case where the automatic conversion won't be performed, there could be a kind of bug. Could you please elaborate the situation, including answers to these questions?
  • What error message appeared?
  • What format reader/writer are you using?
  • What version, build number of FME are you using?
  • April 9, 2018
Consider inserting an AttributeValidator somewhere to check that the string attribute indeed contains a valid integer, e.g.
You could direct the "Failed" port of the AttributeValidator to an Inspector to check what's going on.
Depending on the output format / FME version it might also be necessary to use a NullAttributeMapper to map any empty strings to proper NULL values before the writer:
  • April 9, 2018
@david_r When I use an attribute validator, I get Attribute 'apn' with value '3862110200' fails check for Type is 'INT'
    @takashi
    • The error I get is: 2018-04-09 09:04:44| 2.7| 0.0|ERROR |The invalid value '3870900800' was supplied to the field 'apn' for the table/feature class 'sde.account_to_apn_match'
    • version FME(R) 2017.1.0.0 (20170731 - Build 17539 - WIN32)
    • The reader is SWORLDSWAF; the writer is GEODATABASE_SDE
    • April 9, 2018
    Hi @ieukcoca, the value 3862110200 is greater than the upper limit of 32-bit integer = 2147483647. 'integer' type in the Geodatabase SDE format represents 32-bit integer. Probably it's the reason why the writer rejected writing the value. If so, it's a limitation according to the format specifications, not a defect or a bug of FME.
    Try changing data type setting in the writer feature type to one which has enough valid range to save 3862110200. e.g. integer(n) (n=10), double, or double(n, m) (n=10+, m=0)
    • April 9, 2018
      @takashi
      • April 10, 2018
      Thanks @takashi That makes total sense!
