FME 2019 server LDAP authentication
  • April 1, 2020
  • 46 views
robotix
Forum|alt.badge.img+10
Every single time I try to log into the FME server I get a failed login. The second time it succeeds.
Every time.
Unless i leave chrome open. Then I can log out and log back in without a problem.
Using LDAP. No other issues with LDAP anywhere.
This is always the message:
"LDAPException(resultCode=85 (timeout), errorMessage='A client-side timeout was encountered while waiting 10002ms for a response to simple bind request with message ID 2 ....."
A time out message and authentication failed.
I did a little reading on it and found a bunch of inconsistent java mumbo jumbo.
Anyone have ideas on how to fix this? Its super annoying.
Thanks!!
Best answer by robotix
Just need to resynchronize the AD connection once in awhile and the issue goes away.
robotix
  • December 21, 2020
