I need help with FME Data Streaming Service. I am having trouble serving up a pdf file in a browser. I am using the DataFile writer to write my pdf because my pdf comes in binary form. It all works in workbench, but when I try it in FME Server as a Data Stream it downloads the pdf with the workbench name and a .fmw as the extension. If I change the extension to .pdf my pdf is there and I can open this. I would think that FME should serve up the pdf with the file name I specified in the writer. Any help would be greatly appreciated.
