I understand can use the coordinateSwapper transformer to switch Y <> Z values in the wavefront obj file. But can I also change the sign of the y-values (says from -ve to +ve) as well?
kiabee
saraatsafe
Forum|alt.badge.img+8
  • September 12, 2023
Hi @kiabee​, unfortunately the CoordinateSwapper doesn't have this capability, however you can try to use the 3DAffiner transformer with these settings instead:
3DAffiner transformers with the settings A= 1, B= 0, C= 0, D= 0, E= 0, F= 0, G= -1, H= 0, I= 0, J= 1, K= 0, L= 0
kiabee
  • September 16, 2023
Oh. That's great. Thanks.
