change Detection
  • September 24, 2019
  • 17 views
danpaoly
I am trying to setup a workbench for change detection where multiple users will upload data for change detection. I need to be able to handle the following cases
1. User 1 adds features to fgdb and uploads. Writer fgdb has 4 features now
2. User 2 adds features to a separate fgdb that does not contain user 1 features. Writer fgdb has 8 features now
3. User 1 now has fgdb with all 8 records, he deletes two records and uploads. Writer fgdb should have 6 features now.
Here is a screenshot of my workbench. I can get item 2 to work but not 3.
thomas_g
Forum|alt.badge.img+12
In this case you have to delete the connection coming from the "Deleted"-Port of the ChangeDetector, as you don't want to have these features in your Wrtiter-GDB. If there are any features in your Writer-GDB, you want to delete as well, you can check-in the "Overwrite existing Geodatabase"-Parameter or create the fme_db_operation - attribute on features coming out from the "Deleted"-Port and set them to the value "delete"
