I have a Civil3D dwg file and have tried so many parameters in the reader properties to try to see if I can see the custom "Note" field that is in there to no avail. The creator of the dwg file said it's embedded in the cogo points layer and I see the cogo points layer and associated fields but not that custom field. Is there something that I'm missing? Thanks!
