Missing annotations within the canvas.
  • September 15, 2016
  • 45 views
hsamor
At some occations, the annotations made by a colluege is not visible at next time opening the same workspace.
Thus, while trying if it is only "annotations" that disapear, or if also the "attached Annotations" or Bookmarks are affected - we found out this:
Addning a right click "attach annotation" to any transformer, save and exit, folloved by re-opening the workspace - they all are magically there again!!
The first thing I'd confirm is that you're both using the exact same version of FME, even down to the build number. Lots of weird things can happen otherwise.
