Directory Watch strange behavior
roberto
Hi.
I'm working with directory watch and facing some issues. Sometime the trigger fires the workspace properly (once) and sometime it fires it several times (more than ten) in a second. Not clear to me what's happening. The workspace simply runs a sql command and (exiting python procedure) sends an email.
Thanks for support
Roberto
itay
Forum|alt.badge.img+17
  • December 2, 2016
Hi @roberto maybe the following tutorial might provide some explanation when using FME Server 2016 with the publication filter possibilities.
If doubting I would contact Safe about it.
Hope this helps
roberto
  • December 2, 2016
Thanks a lot. "Unfortunately" the published workspace works in a different, inexplicable (to me) ways. Sometime it works properly, sometime not. I will try to contact Safe. Regards
jdh
Forum|alt.badge.img+28
  • December 2, 2016
the directory watcher is erratic with unc paths and subdirectories. It's improved in 2016 over 2015, but is still not terribly reliable. I second contacting Safe with examples.
itay
  • December 2, 2016
As @jdh and @aaronkoning mention there seems to be some issues with the subscription.
https://knowledge.safe.com/questions/37230/stop-create-notification-spam.html
