FeatureWriter using xlsx giving out fme_* attributes as rows
  • September 13, 2018
  • 6 views
How and why are these created when they aren't visible?
Like:
Type Count
fme_feature_type 0
fme_geometry 0
fme_type 0
QA_Camera pos. 0
QA_Clock position of obs. 0
QA_Comments 0
QA_CP value 0
QA_Date of Observation 100
QA_Depth extra points 0! Resend
regards
andre
xiaomengatsafe
Forum|alt.badge.img+3
Hi @andre, can you attach your input data and the workspace that exhibit this problem? It might be difficult to know what's happening without seeing those. Thank you!
  • September 14, 2018
Hi, @xiaomeng. I can send you a fmwt file but isn't too keen on posting it here. I'm on FME Esri Edition build 18305.
Hi @xiaomeng, just found that this issue is a bit of a non-issue thing. The reason for my written xlsx file had such fme_* events was due to attributeexploder->aggregator in the _attr_name. So by simply remove such values all is good. Thanks, andre
xiaomengatsafe
Hi @andre, happy to hear that you've figured out the cause of the problem and fixed it! Great work!
