Convert RTF to plain text
Hi all.
I have an oracle-database from which I read spatial data. Thes objects have attributes with textstrings up to 4000 charachters. The strings are formatted as RTF, se sample below
{\\rtf1\\ansi\\ansicpg1252\\deff0\\deflang1033{\\fonttbl{\\f0\\fnil\\fcharset0 Helvetica;}}
\\viewkind4\\uc1\\pard\\b\\f0\\fs17 . * (T) Oslofjorden. Oslo. Sjurs\\'f8ya. Lysb\\'f8yer. Nye posisjoner (\\i Light buoys. New positions).\\i0
\\par }
 Is there any way to convert these RTF-fields to plain text in FME? So far I havent been able to find any specific transformer that allows me to do this.
Does anyone here have any suggestions maybe?
Thanks in advance
-Tobias P.
  • June 27, 2014
you will most probably have to use a script inside a PythonCaller to convert the RTF blocks into plain text.
Here is a discussion (http://stackoverflow.com/questions/1337446/is-there-a-python-module-for-converting-rtf-to-plain-text) about various modules that support this conversion (you'll have to download and install them into the FME Python interpreter first).
David
  • July 2, 2014
Thanks! I also googled a bit and saw that the solution probably would be a python script. I got some help from safe support and conversion runs excellent.
  • July 2, 2014
Hei,
godt å høre at det løste seg, lykke til med sjødataene :-)
David
