Using a % symbol in a choice type parameter
Forum|alt.badge.img+35
Is it possible to use a % symbol in a choice type parameter?
e.g. if i wanted the parameter options to be %y%m%d or %d/%m/%Y
gio
Forum|alt.badge.img+15
  • June 18, 2019
I cicrumvent the problem by using choice with alias.
The alias i then use for further control.
  • June 18, 2019
I'm not able to use a % in either the display name or the value in the choice with alias
Hi @egomm,
Unfortunately the GUI for Choice parameters is not properly handling that character as it is used as the separator between different choice values so currently setting %Y%m%d will become three choices: Y, m and d. I have raised issue FMEDESKTOP-9147 to request this is fixed.
As a workaround I would suggest using a different symbol and then using a ParameterFetcher > StringReplacer in your translation to rectify this.
