Adding Two Time Fields
  • April 17, 2019
  • 15 views
Hello,
I am looking to combine two time fields to create a new column output. I've tested a lot of functions and time formats but can't seem to get it right so maybe someone in the FME Community can help.
My first field is a specific time of day (departure_time), and I would like to add a second time field (travel_time) to achieve a final column with arrival_time.
departure_time and travel_time were originally in %H:%M:%S, will I need to convert these formats prior to a calculator? is calculation between two time fields even possible?
Any help would be much appreciated!
erik_jan
Forum|alt.badge.img+18
  • April 17, 2019
Have a look at the DateTimeCalculator transformer.
That should be able to do these calculations.
Maybe the DateTimeConverter is useful, but I think that should not be necessary.
Hope this helps.
