It would be great if there was the ability to add annotations for each line in an AttributeCreator/AttributeManager. Either as an additional description column or within the Text/Arithmetic editor as commented out text. Once you start having nested functions it can get quite difficult to unpick and if there are many attributes being trying to detail it all in an annotation attached to the transformer can be quite unwieldy.
