I'm new to FME and the Vmap/VPF format, And I would like to now how to convert an ESRI shapefile, obstacles (points with attribute height), to the VPF format. Is there someone who can guide me?
Best answer by paullfv
Ok, I see that it is a bit different from other formats, it seems like there is a lot of special things to understand. How do I do if I'd like to save a Shape file with points (attributes: id, height and a geometry:2D-point) in VMAP1?
Kind regards,
Paul
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
