How to convert esri shapefile to multipatch
limo
Forum|alt.badge.img+8
Is there a possibility to convert an esri shapefile (geometry: polygon) to esri shapefile (geometry: multipatch) ?
If I try this directly Reader Esri shapefile --> Write Esri shapefile (geometry: Multipatch) I have no geometry only the attributes.
Does anyone know how to convert to multipatch?
Best answer by owen
Aha ok then I think you'll need to add a FaceReplacer
owen
  • March 9, 2022
It might want 3d geometry, maybe try a 3d forcer?
limo
  • March 9, 2022
the input polygons are already with z-values (polygonZ)
owen
  • March 10, 2022
limo
  • March 10, 2022
Yes @owen​ thanks for your hint. With face replacer I can convert it into multipatch. But I must also use GeometryValidator. Because sometime polygons are not planar. And this doesnt work for FaceReplayer. Afterwards I can aggregate these objects focused on GMLID by using aggregator. As a result I have one multipatch for each building!
