Python Exception <ModuleNotFoundError>: No module named 'cx_Oracle'
r_parlapalli
I am migrating FME 2017 workspace to 2020 version.
in startup script, python script is having import cx_Oracle statement.
when i published the workspace on FME Server 2020 version, i get below error.
please share your ideas to fix it.
  • April 23, 2021
You'll have to install this module into your FME Server installation, as it is not included. See
If you need a pre-compiled version for Windows, you can find it here: https://www.lfd.uci.edu/~gohlke/pythonlibs/#cx_oracle Take special care to observe the Python version and 32- vs 64-bit versions, both have to match exactly with the Python version you'll be using on FME Server.
r_parlapalli
Thanks David for your quick response. Let me try it and share an update.
r_parlapalli
One question: when i was isntalling FMEsever, there was an option to check python interpreter along with FMEServer. will it help, if i select that and install the FME?
r_parlapalli
Hi @david_r​ ,
i have executed below command, but still not finding any .pyc files related to cx_oracle package. Any suggestions on my approach?
python -m pip install cx_Oracle --target C:\\Users\\<user>\\Documents\\FME\\Plugins\\Python
