How can I get an oriented bounding box?
I am trying to create a 2D oriented bounding box around the point cloud of a roof with a boundingboxreplacer and the appropriate option, but the result is the same as a standard 2D bounding box. I expect an rotated bounding box. What am I doing wrong?
Best answer by nielsgerrits
You need to convert the PointCloud to a Single Multipoint using a PointCloudCoercer before you feed it to the BoundingBoxReplacer. Same principle for the HullAccumulator.
Example workspace added.
PointCloudCoercerParameters
nielsgerrits
Forum|alt.badge.img+54
  • March 3, 2021
  • March 3, 2021
Yes, that did it. Thanks!
