Email Not Being Sent From Scheduler
I have a workspace that I published to FME Server (2020.2.4) that contains an Emailer transformer. The email sends correctly from when I run the workspace in Workbench and also when I run the workspace in FME Server. But when I create a schedule for this workspace and run the workspace from the Scheduler the email is not sent.
Do I need to do some additional steps or configuration to get the Emailer to work from the Scheduler?
virtualcitymatt
Forum|alt.badge.img+35
Pretty strange indeed. How is the emailer configured? does it use any published parameters? What is the log message?
  • August 3, 2021
There are no published parameters. There are no warnings or errors in the logs and the logs just do not contain any information about the emailer running.
I re-published the service this morning and it now works from the scheduler even though I did not make any changes to the workspace, service, or schedule - strange.
I will keep my fingers crossed and maybe it will continue to work.
Thanks for you response,
David
virtualcitymatt
dkirouac wrote:
David
That pesky ghost in the machine! Perhaps the other emails just got stuck in the spam folder?
