FME desktop won't load data from wfs service.
  • May 15, 2018
  • 57 views
pschout
Participant
I try to load data from this wfs : https://www.vaarweginformatie.nl/wfswms/services?SERVICE=WFS&VERSION;=1.1.0&request;=GetFeature
but it gives some errors. I use the wfs reader in FME desktop 2015, I see and can select the different feature types in the wfs but it won't load the data.
The reader generate the next error : The top-level element declaration referred to by the 'substitutionGroup' attribute is missing from the XML Schema
QName: 'gml:AbstractFeature' | namespace uri:'http://www.opengis.net/gml'
What is going wrong?
danilo_fme
Forum|alt.badge.img+41
  • May 19, 2018
Hi @poppendamme
Did you open this url in another software? I inserted in the brownser and didn't work:
<?xml version='1.0' encoding='UTF-8'?>
<ows:ExceptionReport xmlns:ows="http://www.opengis.net/ows" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.opengis.net/ows http://schemas.opengis.net/ows/1.0.0/owsExceptionReport.xsd" version="1.0.0">
  <ows:Exception exceptionCode="InvalidParameterValue" locator="typeName">
    <ows:ExceptionText>Either the typeName parameter must be present or the query must provide feature ids.</ows:ExceptionText>
  </ows:Exception>
</ows:ExceptionReport>
Thanks,
Danilo
