FME Desktop 2022: “AttributeCreator” fails to copy a field into another using the arithmetic editor,
jamal
Forum|alt.badge.img+5
In the screenshot below, I wanted to copy the “fme_text_string” field to the “F1” but appears not work except for the first record.
What could be the issue here?
The data and workbench are attached
Clip_227
Best answer by dustin
Try using this expression into the AttributeValue.
@Evaluate((@ReplaceString(@Value(F1),",","")*2))
dustin
Forum|alt.badge.img+31
  • March 10, 2022
You shouldn't need an arithmetic calculation if you aren't making any changes to the fme_text_string value. Simply make the Attribute Value in the AttributeCreator = fme_text_string.
You can also do without the TestFilter by using the Conditional Values function in the AttributeCreator.
jamal
  • March 10, 2022
Thank you for the help.
I never figure it out why it fails when using arithmetic editor
Clip_230
jamal
  • March 10, 2022
The issue is replicated as I wanted to multiply “F1” field with 2, for example. It just multiplies the first record and fails for other.
Clip_231
dustin
  • March 10, 2022
jamal
  • March 10, 2022
It works fine. However, as I applied it to another field, it fails as per the second screenshot
Is this code generic?
Clip_236
Clip_237
DanAtSafe
Forum|alt.badge.img+18
  • March 11, 2022
The code is generic for any attribute where you want to remove commas. But to remove "%", convert the number to its true value, and multiply by 2, try
@Evaluate((@ReplaceString(@Value(Percent_Legend),"%","")*0.02))
jamal
  • March 11, 2022
Thank you very much for the help. It works fine
Clip_238
