How can i create a question?
fmelizard
Forum|alt.badge.img+18
Keep your question relevant to this space.
Make sure you've selected the correct space to post your question. This way your question is most likely to be answered.
Check for existing answers.
You can search for your question to see if an answer has already been provided. Avoid posting duplicate questions.
Keep it clear and concise.
Other users will only be able to help you if you provide enough details and are clear about your question. Use the body field to provide the details of your question.
Be polite.
Typing questions and comments in all caps and using unnecessary punctuation (!!1! / ???) will not increase the likelihood of your question being answered.
Be the first to reply!
