I am getting a fatal error while translating a DGN file to DWG format.
Object Data Writer: Failed to create object data table named 'XXX' in dataset
A fatal error has occurred. Check the logfile above for details
Kindly help me to translate a DGN file to DWG along with symbology like Colors, line styles, Cells (in DGN) = block (In CAD).
Thanks in advance.
Hi.
Here in Forum has any linls about this process DGN to DGN. You can check this, please:
knowledge.safe.com/questions/5258/dgn-to-dwg-conversion.html
If this link is not good for your case, can you send us your Workspace template to understand the error?
Thanks,
Danilo
Hi @dheeraj
could you please share your workspace and full translation log? It looks like something goes wrong at writing - but it is hard to tell what and why without any additional information.
