Open
Certificate Authentication RabbitMQ
Related products:FME Form
  • August 18, 2025
  • 63 views
jelle
Forum|alt.badge.img+22
For the HTTPCaller, the certificate authentication was introduced. (see
Is it possible to add it to the RabbitMQ Hub Transformer as well?
PierreAtSafe
Forum|alt.badge.img+8
NewOpen
jelle
  • September 18, 2025
NewOpen
What does this status mean, ​@PierreAtSafe ?
PierreAtSafe
  • September 19, 2025
Hi ​@jelle
We are using this status with two goals in mind:
  1. To show you that we had a look at your Idea and we use the Open status as opposed to Archiving it (basically saying that this is a valid idea, not something we don’t see ourselves doing right away).
  2. See how much interests the idea can gather among the community
If we see it gaining traction with the community (or we believe this is a overall valid product improvement) we then investigate in more detail and put it on the roadmap for a future release if we believe the development and maintenance cost is worth the investment.
Hope that answers the question!
Cheers
