If I use the JSON reader, I get a flattened list with lots of attributeX values. (yes, that is what the doc says it does).
I see some examples of people using the FileTextReader and then JSONFlatten it out and exposing attributes. Is that the way to go? I think this should be easy, and yes, the path is a windows UNC, so I want to be able to use the in the RasterReader transform, I hope it understands UNCs.
{ "Zoom" : 9, "CenterLat" : 50.055084228515625, "CenterLon" : 19.938812255859375, "FrameList" : [ { "idx" : "22504704", "type" : "CIB10", "path" : "\\\\\\\\TEST-EGPL\\\\F\\\\SIS\\\\NGA\\\\CIB\\\\CB10S0009601\\\\RPF\\\\N51E020\\\\000MJ046.I13", "date" : "1995-03-06T06:43:06.000Z" }, { "idx" : "22504705", "type" : "CIB10", "path" : "\\\\\\\\TEST-EGPL\\\\F\\\\SIS\\\\NGA\\\\CIB\\\\CB10S0009601\\\\RPF\\\\N51E020\\\\000MJ126.I13", "date" : "1995-03-06T06:43:07.000Z" }, { "idx" : "22504706", "type" : "CIB10", "path" : "\\\\\\\\TEST-EGPL\\\\F\\\\SIS\\\\NGA\\\\CIB\\\\CB10S0009601\\\\RPF\\\\N51E020\\\\000MJ226.I13", "date" : "1995-03-06T06:43:08.000Z" }, { "idx" : "22504708", "type" : "CIB10", "path" : "\\\\\\\\TEST-EGPL\\\\F\\\\SIS\\\\NGA\\\\CIB\\\\CB10S0009601\\\\RPF\\\\N51E020\\\\000MJ326.I13", "date" : "1995-03-06T06:43:08.000Z" },
