Lookup and replace where lookup is to match 2 criteria
Hi folks,
New to FME and am struggling with working out how to set multiple feature values based on a multiple criteria lookup
My source looks like the following
system_iddescriptionpurposeST1ST21Scout HallCC
2Town HallT
3Council OfficeWS
My translation table looks like the following
SelectionTypeRAMM.fieldRAMM.DescriptionT1BUILDUSEramm.ud_buildings.purposeMUSHERCULTBUILDUSEramm.ud_buildings.purposeHBHERCULTBUILDUSEramm.ud_buildings.purposeCCCOMMUNITBUILDUSEramm.ud_buildings.purposeTPUBLICBUILDUSEramm.ud_buildings.purposeWSMUNICIPLBUILDTYPEramm.ud_buildings.purposeMUSMISCBUILDTYPEramm.ud_buildings.purposeHBMISCBUILDTYPEramm.ud_buildings.purposeCCCOMYHALLBUILDTYPEramm.ud_buildings.purposeTPBTOILETBUILDTYPEramm.ud_buildings.purposeWSDEPSTOREBUILDTYPEramm.ud_buildings.purposeFESMISCBUILDTYPEramm.ud_buildings.purposeCCSCHANGERMBUILDTYPEramm.ud_buildings.purposeRCCOMYHALL
I want to update ST1 using the SelectionType BUILDUSE and ST2 based on BUILDTYPE based on the purpose in the source to give me the following
system_iddescriptionpurposeST1ST21Scout HallCCCOMMUNITCOMYHALL2public ToiletTPUBLICPBTOILET
3Council DepotWSMUNICIPLDEPSTORE
Ive used FeatureMerger to do this on individual features but not multiple features
Best answer by ebygomm
I would aggregate your translation table based on RAMM.Description, and build a list containing the T1 data. You can then featuremerge in the normal way and rename list item 1 to be ST1 and list item 2 to be ST2
@left65 Example attached
merge2.fmwt
Forum|alt.badge.img+35
  • October 21, 2019
merge2.fmwt
  • October 21, 2019
merge2.fmwt
Hi ebygomm
Thanks for the response but i have never used the aggregator so am not sure what to do or how this would work. Can you give me any hints or perhaps an example
  • October 22, 2019
merge2.fmwt
Thanks so much, that works perfectly
