FME Weekly Quiz: Can you outscore Jen Luther Thomas (June 2020-2)
  • June 8, 2020
  • 13 replies
  • 47 views
mark2atsafe
Forum|alt.badge.img+59
Hello everyone,
Your Safe quiz opponent for this week is... Jen Luther Thomas (@jlutherthomas) also known by her Twitter handle of mapgirll.
Jen is a "Technical Experts Team Lead for FME Server" at Safe, which means she leads one of the two support teams responsible for handling FME Server cases.
A fellow Brit (there are quite a few of us at Safe) she is a frequent participant in webinars, writes blog articles, originally set up the community "Holiday Hackathons", and does a lot more brilliant things besides.
She would be a tough opponent on the subject of Server... but unluckily for her I haven't included any Server questions this week! Will it hold her back? You'll have to take the quiz yourself to find out:
https://demos-safe-software.fmecloud.com/fmeserver/apps/FMEQuiz
jelle
Forum|alt.badge.img+22
  • June 8, 2020
Topping up the perfect scores with 1
jdh
Forum|alt.badge.img+40
  • June 8, 2020
So who actually solved the anagrams instead of guessing?
Forum|alt.badge.img+46
  • June 8, 2020
I made a workspace with a bit of python to solve them for me
import fme
import fmeobjects
from collections import Counter
def processFeature(feature):
    transformerlist = [x.lower() for x in feature.getAttribute('text_line_data').split('\n')]
    a = [i for i in feature.getAttribute('_list').lower()]
    for transformer in transformerlist:
        if len(transformer) == len(a):
            t = [i for i in transformer]
            if Counter(a) == Counter(t):
                feature.setAttribute("matched_transformer",transformer)
mark2atsafe
  • June 8, 2020
Well done. That's the only one so far.
mark2atsafe
  • June 8, 2020
import fme
import fmeobjects
Beautiful! I wondered if anyone would use FME to solve the anagrams. Great work.
  • June 8, 2020
A pure FME solution is fairly straightforward to
jdh
  • June 8, 2020
I did something similar to this, only I used python to sort the strings alphanumerically.
Forum|alt.badge.img+62
Who-hoo! Good job!
4/6, I had to guess the anagram one...
  • June 9, 2020
Yup, fun little challenge: anagram_checker.fmw
Bonus question: which two transformers are anagrams of themselves? :-) Answer in the attached workspace.
oscarwillems
Forum|alt.badge.img+18
  • June 9, 2020
I went through all the quiz results and i ended up on 65 perfect scores. From the question options the max was 58 though
mark2atsafe
  • June 9, 2020
Ah, well I missed out the first five weeks because I didn't have them recorded automatically. I guess at some point I should go back and make sure I have everything.
jonas_nelson
Forum|alt.badge.img+28
  • June 10, 2020
*Ahem* I think it is a little bit on the wrong side to reveal answers before the quiz has ended...
