Remove Fields Issue
  • September 16, 2025
  • 49 views
francisco_1988
Forum|alt.badge.img+5
I can't remove the "issue." fields. I tried deleting them with Attribute Manager and AttributeRemove without success. Could someone tell me how to do this deletion?
I don't think there are cases where any attribute couldn't be removed by AttributeManager or AttributeRenamer. Can you elaborate the situation more specifically?
It would be better if you could share a minimal set of a workspace example and a sample dataset to reproduce the situation.
francisco_1988
Hi Takashi!
These are the fields circled in red.
Forum|alt.badge.img+46
Your upload doesn’t appear for me. Are they list attributes?
