Volume Calculation
  • January 30, 2013
  • 25 views
Hello FME Team, I was wondering if anybody has calcuated Volume of a pipe before? I have a Water network of pipes in GeoMedia and would like to calcuate the volume and output it as a new attribute on the existing feature class.  I have Pipe Length & Pipe Size to play with for attributes.
Thoughts?
philippeb
Forum|alt.badge.img+20
  • January 30, 2013
VolumeCalculator?
  • January 30, 2013
No Philippe, their is only the VolumeUnitConverter,  which works if you have a column with the volume already calculated and want to convert it to another unit of measurment.
philippeb
  • January 30, 2013
Which version of FME dow you have? In FME2013 I have VolumeCalculator. VolumeUnitConverter is from the FME Store.
Anyway, I would use the ExpressionEvaluator to simply make this :
v = h?r2
h would be your length
r would be the size
