Can't create FME Flow backup
  • March 26, 2024
  • 105 views
marias
Forum|alt.badge.img+10
I am trying to create FME Flow backup in order to upgrade it to the newer version.
Current version is FME Server 2020.2.
I am getting the following error:
Tried many times and cleaned drives a bit. Previous backup was about 100 Mb. So it should be more than enough space for the new backup:
What can be wrong, how I can fix this? Thank you in advance.
marias
  • March 26, 2024
Emptied drive D to 11GB, but still no luck.
hkingsbury
Forum|alt.badge.img+67
  • March 26, 2024
Do you have any shared resources that are large? These will likely be getting backed up as part of it
You can see more details here: https://docs.safe.com/fme/html/FME-Flow/WebUI/Backup-Restore.htm
marias
  • March 27, 2024
Yes, thank you. It turned out that we had old data that I didn't notice at first.
Checked FME Server system share folder. On Windows, the default path is: C:\ProgramData\Safe Software\FME Server.
Removed unneeded data and backup was created successfully.
