Hi, I am trying to install FME Desktop 2020.2.4 from https://www.safe.com/support/downloads/. I would like to now if the software installed from this path is compatible with GE Smallworld. Please advice. Thank You.
  • July 5, 2022
  • 36 views
JennaKAtSafe
Forum|alt.badge.img+8
Hi @anshuhk15​ , you can find out more about FME's compatibility with Smallworld here. At the bottom of the page you can find two FME Product Options for GE Smallworld Users. Hope this points you in the right direction.
