Why is the workspace field empty after hitting [apply] in dynamic workspace dialog?
  • January 2, 2024
  • 59 views
worjak
Forum|alt.badge.img+4
When in automations you work with the dynamic workspace runner the workspace field blanks after hitting [apply]. It is annoying and confusing because some times the chosen parameter value is not forgotten and some time it is forgotten!? I believe this is a bug but have not seen any mentioning of this in here. So appologies if this is a known issue expected to be solved in next release!
Before [apply]:fme-flow-dyn-wspc-not-blank-Skærmbillede 2024-01-02 162333After [apply]:
fme-flow-dyn-wspc-blank-Skærmbillede 2024-01-02 162333
sanaeatsafe
Forum|alt.badge.img+8
  • January 3, 2024
Thanks for reporting this! I'm unable to reproduce the issue on my local FME Flow installation, so far. What FME Flow version and build are you using? OS? Thanks.
worjak
  • January 4, 2024
Thanks, here are our details:
FME Flow 2023.1.1.1
Build 23636 - win64
christian_dan
For me it also occurs in FME Flow 2023.2.1 (Build 23774 - win64)
