How to group date according to date ranges?
  • July 21, 2021
  • 132 views
I want to group materials and pipe length according to different age barckets (of say 2 or 5 or 10 years)...how could i do in FME?
Please see my sample data:
danilo_fme
Forum|alt.badge.img+52
  • July 21, 2021
Hi @ppp19​
Your source data is not here.
  • July 21, 2021
Hi @danilo_fme​
Attached snapshot from my data!
caracadrian
Forum|alt.badge.img+23
  • July 22, 2021
If you want to group by year you should first extract the value of the year.
Use DateTimeConverter set with Input Format %d/%m/%Y and Output Fomat %Y.
Than use AttributeRangeMapper. Use the Generate button to auto-create your ranges (input a min, max year and the number of ranges - do the math for 2, 5, 10 years).
Use the value of the range attribute (_looked_up by default) to group features
  • July 27, 2021
Hi @caracadrian,
That worked perfectly according to my expectations. Thank you so much for your help.
Regards
