Best Answer
How to see boundaries traslation from .osm
  • February 3, 2020
  • 8 replies
  • 42 views
geomax
Forum|alt.badge.img+3
Hello,
If I load a file .osm downloaded from OSM in Qgis I can see in the table all traslation present for admin boundaries.
I tried to do the same in FME but I am not able to see these attributes.
Sombody can help me to understand how to do?
Thanks
Max
this is what I see in Qgis and what I would see in FME.
Best answer by geomax
Hello,
the file that I am using is too big to attach. I'm working on Hamburg and I dowloaded the file from geofabrik server.
I downloaded another file with the same schema.
I tried also to load data using the .xml schema present in FME folder but I have the same result.
I can see many attributes except the languages.
Thanks for your help.
Max
osm.zip
Forum|alt.badge.img+62
Just out of curiousity, if you open the file in the FME Data Inspector and check the table view, do you see those attributes?
geomax
  • February 4, 2020
Hello,
no. and I don't understand why.
Max
Hello,
Max
Can you post a screenshot? And maybe share the data here?
geomax
  • February 4, 2020
Hello,
Max
osm.zip
Hello,
Max
osm.zip
Aha!
So what happens is that FME doesn't show all of the columns available in the data model by default, because there's so many of them.
In the Data Inspector you can click on the columns button in the table view and select which columns are visible.
In the FME Workbench you'll need to use an AttributeExposer to show the attributes, you'll have to manually enter the exact attribute name there.
geomax
  • February 4, 2020
thanks for the answer, but I have still doubts. I tryied the attribute exposer without result.
Attached what I see. Probably do I some error during the loading of the dataset?
I move the dataset directly from the folder into the FME canvas and choose Openstreetmap (OSM) XML without other setting. Is it correct?
Thanks
Max
Thanks
Max
Yes, it's the OpenStreetMap XML format and it looks like you're on the right path for the AttributeExposer. The way you've set it up will expose the name:en attribute.
However, if you add a reader for the dataset it's probably better to select the individual feature types option. That'll give you a bit more control.
geomax
  • February 5, 2020
Hello,
I understood what you mean.
Thanks for your support.
Max
