I need help joining a table based on whether or not a feature falls within a date-time range.
Table A: Has an attribute with unique recorded date-times for all 3,233 records
Table B: Has a "Start Date-Time" and an "End Date-Time" field for all 29 records
I built this query:
and it was able to join and return 2,731 records that met the criteria.
Here's a sample of what was joined:
My issue now is how to join return the other 502 records that may not fall the range listed above. I've tried several iterations such as NOT BETWEEN, IS NO, <>, etc.
Any advice would be appreciated! Thanks.
Note: Tables are generated from a CSV so that's why I chose InlineQuerier.
FME 2018.1.1.2 (Build 18586) 64-bit
Isn’t it a different type of join you’re looking for? Possibly a right join maybe.
https://stackoverflow.com/questions/38549/what-is-the-difference-between-inner-join-and-outer-join
Agree. This type of join might be what you need.
Are you looking for all records returned, including unmerged in one query, or a separate query to return only unmerged?
Something like this for all records
SELECT * from mergedRecords M
left join
aRecords A
on M.fullDateG between A.startFullDateA and A.endFullDateA
or this if you just want to return unmerged
SELECT * from mergedRecords M, aRecords A
on M.fullDateG not between A.startFullDateA and A.endFullDateA
Unfortunately, I get the following error that states RIGHT and FULL OUTER JOIN are not currently supported. I would love to use a a RIGHT JOIN here.
left join
aRecords A
@egomm the top script returns 3,236 records which is 3 more than 3,233 I originally started with. I ran a duplicate filter and inspected the 3 records and it is data I need to keep. I'll take this flow for now and swap out those 3 records some how. But it would be nice to avoid all of the extra transformers. Note: I tried SELECT DISTINCT and just SELECT and both statements returned the 3 extra records.
That’s interesting as only ever used inner joins.
"left join" is applicable.
Do you have overlapping periods in the table you are matching to? This would result in additional values as all matches in the left table are returned.
Ended up leveraged the 'Adjacent Feature Attributes' function to back-fill missing data fields.
