Hello people, i splitted one DXF-File into 4 separeted DXF-Files. One of them i tried to open in ArcGIS, but can not see the features there. Somehow DXF-Files, which were written through FME, could be read only in FME Viewer, but not in ArcGIS. Do you have any ideas, how can i fix it? I tried already all possible format of DXF in FME to write, but still does not work.
(the main DXF-File can be open and the features could be seen in ArcGIS as well)
