FME 2017 crashes when done and when closing
  • March 1, 2018
  • 7 replies
  • 71 views
I have a lot of scripts that all write to point feature classes in a 10.4.1 SDE Database in SQL Server 2012.  The source comes from one of 3 databases types, SQL 2012, SQL 2014, or Oracle 11G.  They all are the same as far as errors go so either it's my SDE or FME itself.
I even inspected everything I could and on a few I did get error while running and cleared up those small data issues, but they all produce the same error codes on crash dialog box I show at the bottom of this post when I close the Inspector app.
I have tried to redo from scratch a few of my scripts but they ALL are crashing like I show below.  I am using the latest version 2017.7.27.17725, I had 2017.7.27.17539 and it did the same exact thing and I thought upgrading would do the trick, but no....
I have redone all my readers and writers, fished through all my data and data types, redone queries, redone my writer feature classes in my SDE, and even filtered the coordinates to fit in the state because we are using UTMs in the final feature class and I know a funky number can produce problems when reprojecting to UTM.  I have gone through everything I can think of for troubleshooting.  I turned on the debugging log and have only the errors below but I don't think they are worth anything.
I also put in a filename for the "Failed Feature Dump filename" in the Advanced Parameters of my Writer and nothing was rejected or written to this file.
The only thing that comes to mind that changed was an upgrade to ArcGIS 10.5.1 on this machine.  There are no backward compatibility issues on ArcGIS between 10.4 and 10.5, but perhaps FME doesn't like something in 10.5?
Note that my translations all error at the end of the summary when everything had been written and long after these errors appear in the log.
BADNEWS: File C:\Program Files\FME2017_1_2_1\metafile\MULTI_WRITER.fmf could not be opened (tabrdr.cpp:161)
BADNEWS: No MULTI_WRITER dataset name was specified (couldn't find a value for `MULTI_WRITER_DATASET') (writrimp.cpp:773)
BADNEWS: File C:\Program Files\FME2017_1_2_1\metafile/geodatabaseDefline_.fmi could not be opened (tabrdr_classic.cpp:2715 - tabrdr::ClassicTableReader::TableReaderSource::open) - (tabrdr_classic.cpp:1739 - tabrdr::ClassicTableReader::getRow)
At the end of the log it's like this: (cleaned it up a bit for readability)
...blah blah
Features Written Summary
STATS |SDE.BCA_ALL_SITES_2                    2801
SDE.Update_record                             1
STATS |Total Features Written                  2802
INFORM|Microsoft SQL Server Non-Spatial Reader: Closing `ProjectTracking' . Read operation complete
Translation was SUCCESSFUL with 0 warning(s) (2802 feature(s) output)
INFORM|FME Session Duration: 14.5 seconds. (CPU: 5.4s user, 2.4s system)
INFORM|END - ProcessID: 23452, peak process memory usage: 1105512 kB, current process memory usage: 1078264 kB
Error running translation.
Then this crash box pops up EVERY SINGLE TIME after the error above.
Problem signature:
  Problem Event Name: BEX64
  Application Name: fme.exe
  Application Version: 2017.7.27.17725
  Application Timestamp: 5a601aaa
  Fault Module Name: StackHash_2264
  Fault Module Version: 0.0.0.0
  Fault Module Timestamp: 00000000
  Exception Offset: 000007fe7f93124b
  Exception Code: c0000005
  Exception Data: 0000000000000008
  OS Version: 6.1.7601.2.1.0.274.10
  Locale ID: 1033
  Additional Information 1: 2264
  Additional Information 2: 2264db07e74365624c50317d7b856ae9
  Additional Information 3: 875f
  Additional Information 4: 875fa2ef9d2bdca96466e8af55d1ae6e
Best answer by jacque
@MattAtSafe was right! This is a Windows2008 R2 Server and I had recently had a ton of Windows update issues that I had alerted ESRI to and they created this patch: https://support.esri.com/en/Products/Enterprise/arcgis-server/ArcGIS-Server/10-6#downloads?id=7576
And then I went looking for more patches per Matts suggestion and found this one, and that fixed the FME issues! https://support.esri.com/en/Products/Desktop/arcgis-desktop/arcmap/10-6#downloads?id=7579
yay!
  • March 1, 2018
I think it's my writer but I have no idea why or how to fix it. I'm using GEODATASE_SDE with the ESRI SDE connection file.
  • March 1, 2018
There's also an ESRIReprojector bug too, it causes it to crash without the SDE writer. When I use the CSMAPReprojector or Reprojector without a writer it works.
The writer to the SDE crashes everytime, whether it's alone or with the reprojectors.
This is frustrating.
fmelizard
Forum|alt.badge.img+21
  • March 1, 2018
Hi @jacque,
Are you on Windows 7 or Windows Server 2008? does this sound like you? https://knowledge.safe.com/articles/63592/fme-exe-has-stopped-working-after-updating-windows.html
  • March 1, 2018
Hi @jacque,
I'm on Windows 2008. and yes those are the same updates that were causing ArcServer problems too! I just installed the ESRI patch last week though (ArcGIS Server Geoprocessing Service Startup Patch) and it obviously did not fix FME.
  • March 2, 2018
yay!
fmelizard
  • March 2, 2018
yay!
Great - Thanks for sharing with us @jacque! I will update our article to make sure to add both patches if using both FME Dekstop and ArcGIS Server.
  • March 2, 2018
yay!
Thanks Matt! And yes I have Server and Desktop on the same machine with the 64-bit background processing.
I had a ticket out recently that figured out FME was using Server and not Desktop so all my batch files are altered to use the Desktop version of FME which uses Desktop of ArcGIS. For anyone that cares, this is what I have to do for them (The last part wit the source dataset is a copy/paste from the top of the log window in Workbench and I'm forcing an FME version since we have multiple installed for testing purposes):
set DI_APPLICATION_CONTEXT=DESKTOP
cd C:\\Program Files\\FME2017_1_2_1\\
fme.exe C:\\FME_Scripts\\NDEP\\ORACLE_to_SQL\\ARIS_ALL_PERMITS.fmw --SourceDataset_ORACLE8I_DB "AIR11G" LOG_STANDARDOUT YES
