could i ask how to get in inspector only the lines that intersected with polygon ,
i tried alot with clipper
polygon as input for clipper and lines input for clippee
output from inside ,i got the intersected lines with polygon plus all lines inside the polygon .i want only to have the intersected lines with polygon and delete the rest of lines inside the polygonhow could also give intersected lines specific colour .
Thanks alot
