Archived
Improve options to select attributes in the Text & Arithmetic editor
Related products:FME Form
I would really like the option to double click an attribute in a text or arithmetic editor and have the full attribute selected, i.e. the @Value(attribute_name)
At the moment double clicking on the attribute name only highlights the text inside the brackets. This is no good if you want to double click on a Feature Attribute to swap the attribute
