S3Connector not working with SSL verification even though a S3 resource exists.
  • November 12, 2020
  • 0 replies
  • 28 views
kathyjbryce
Forum|alt.badge.img+4
I'm unable to use SSL with the S3Connector on a FME Server that has valid certs to our AWS. The certs are valid because we have successfully added a resource to the same S3 bucket. If I turn off SSL verification in the transformer, it works successfully. What is different with how the S3Connector works? Has anyone ran into this issue and resolved it?
FME Server 2019.1
Thank-you!
Kathy
